hello
do you know what are likely values of the Cpole parameter for this optocoupler?
CNY17-2
I am talking about when there is round 3mA flowing in the opto diode.
I need the full tolerance range....i.e min and max of Cpole.
This optocoupler will be used with the opto transistor in common emitter connection in an SMPS feedback loop.
We must absolutely know this Cpole value and its tolerance range because our SMPS output LC filter (EMC filter) has a resonant frequency of 8KHz, and we must arrange our smps loop crossover frequency to be at least three times less than this or else we will get output filter interaction and instability.
As you know, Cpole is a parameter which determines the crossover frequency.
The manufacturer wont tell us the data.
CNY17-2
