A
alfordtp
Guest
Instead of modeling the entire assembly, I modeled the top sheet that holds the assembly and assigned a mass at the centroidwith four springs with infinite spring constant to represent the weight of the system. Then I added a gravity load.
How do I constrain the assembly if I want to "lift" itfromfour other holes in the top sheet?
