wtshtf
- Dec 30, 2008
- 3
Can anyone recommend a source of info or literature on the lifting of girders?
My specific question has to do with how to determine the unbraced length of the girder. Since the pick points will either be with slings or some other type of cabled support, the points of support cannot be considered "brace points".
So, my immediate dumb question is: what do I consider the unbraced length? The total length of the girder? I wouldn't think so, because even if I lift if from the extreme ends, the compression flange is not braced anywhere along the girder.
If I determine that the compression flange needs to be braced, I would assume some type of stiffening beam or truss needs to be attached to the flange. How would I determine what this needs to be?
Thanks for any response.
