License Variable for NX9? 1
lharrison
New member
Oct 19, 2011
52
We recently started upgrading to NX9 and noticed that the familiar UGS_LICENSE_BUNDLE environmental variable is no longer used. Internally, we have a custom program written to display who currently has licenses, and toggle buttons so users can easily select an unused license. Previously, new license were selected by altering the UGS_LICENSE_BUNDLE variable, but since it is no longer used, this is not possible. I tried creating a variable that adheres to the new 'SPLM_' convention, but it doesn't appear to work. Anyone know where NX9 stores what license bundles you currently have selected?
Bruce
Lharrison,
The bundle data is persisted in the Windows registry.
There are two interfaces.
%UGII_BASE_DIR%\ugflexlm\LicenseTool.exe (Interactive GUI)
%UGII_BASE_DIR%\ugflexlm\lictool.exe (command line)
The --setbundle or --unsetbundle options could be used by the script that is currently setting en environment variables.
Hopefully this is helpful,
Joe
Usage:
Siemens License Tool CLI [ 6.1.3.1 ]
Copyright (c) 2012 Siemens PLM Software Inc. All rights reserved.
Allowed Options:
-h, --help Print Help (this message) and exit
-v, --version Print version information and exit
-c, --copyright Print copyright information and exit
--getbundle [--components] Get information of all bundle(s) and
component(s)
--setbundle <name> Set bundle(s), example:
--setbundle "BUNDLE1" "BUNDLE2"
--unsetbundle --all | <name> Unset bundle(s), example:
--unsetbundle --all
--unsetbundle "BUNDLE1" "BUNDLE2"
--getborrowable Get borrowable license(s)
--getborrowed Get borrowed license(s)
--borrow <name> [--days <num_of_days>]
Borrow license(s), example:
--borrow "LICENSE1" "LICENSE2"
--borrow "LICENSE1" "LICENSE2" --days 30
--return <name> Return license(s), example:
--return "LICENSE1" "LICENSE2"
--getcid Get composite host ID
--getid Get host ID
--getclientinfo Get the following information from client
side:
Host name
User name
FNP SDK version
License server
--getserverinfo Get the following information from server
side:
Sold to ID
Webkey
Issuer
Version
Toolkit version
Oh, bad news.
This makes my life more difficult. I hate registry settings.
Now our install script needs to modify the registry when the users themselves perform the NX install.
I can't understand why Microsoft is so obstinate in mixing the OS with the applications.
Sooner or later the registry is corrupted and a complete reinstall is required.
Tomas
Microsoft didn't write the license manager, so don't blame them for the application developer using the registry.
The registry does provide a 'hidden' location for applications to store settings, but it is not required. Application settings can be set in files with that applications folder structure.
Ben Loosli
Well that's sort of a bummer, a little more difficult than it used to be. Thanks for pointing me in the right direction!
If anyone is curious, it seems like the registry settings live here:
[HKEY_CURRENT_USER\Software\Siemens_PLM_Software\Common_Licensing]
"NX_BUNDLES"="NX12100N"
If the client install does not include FLEXLM, how can the bundles be subsequently set by use of a script ?
NX 6.0.5.3, NX 9.0.2.5
NX 10 (Testing)
Windows 7 64 (Windows 8.1 Tablet)
Create a reg file by exporting the key from the registry.
Then import into the registry in your script by doing:
regedit.exe /s c:\name_your_exported_reg_file.reg
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3
NX8.5.0 -> NX8.5.3, NX9.0.0 -> NX9.0.2, NX10 Beta
Thanks Anthony.
And to "return" bundles using the registry ?
NX 10 (Testing)
Why would you want to?
Anthony Galante
Most of our licensing is floating, but we have a couple of ADVDES and DESIGNER bundles that we "share" on an as needed basis. Once used, they need to be "returned".
I guess a registry key setting "NX_BUNDLES"="" would work.
NX 10 (Testing)
Are you specifying only one bundle then for a user?
You can specify a maximum of two, so specify their normal one and then add the ADVDES or DESIGNER as a secondary.
It will then be used if the first one is unavailable or if there is a missing function in the first bundle that is in the second.
Anthony Galante
I just remembered and ran a test to check that if you use the Licensing Tool to set the bundle, it will set it in registry, not as a user variable (like in the previous releases of NX).
However if you don't use that tool and set the UGS_LICENSE_BUNDLE variable manually, either by setting it in the environment variables or through a script or env file, NX will work.
This will only work if the registry setting doesn't exist though, so don't use the Licensing Tool.
Anthony Galante
I'm confused now, is UGS_LICENSE_BUNDLE still valid for NX9 ?
NX 10 (Testing)
yes, just don't use the license tool to pick a bundle, otherwise it doesn't create the variable and sets in registry instead.
then if you set the variable manually it won't read it because the registry setting exists.
Anthony Galante
If your trying to see who has the available licenses there is a free tool available from:
I have been using this for NX7.5 & 9.0 works great and the price is right.
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5,NX8.5, NX9.0
Vericut7.3
