Instr13
- Jun 3, 2002
- 12
For controlling condensate level in a LP steam condensate flash drum we are using a globe valve 1-1/2" in a 4" pipe. Calculation shows that flashing occures inside the valve. Any suggestion for retrofitting the existing trim and or changing the piping layout. Process conditions are P1=40.6 psig, P2=18.99 psig, Flow= 6500 kg/hr, Temp=141 deg C.
The valve is about 9 feet below drum outlet nozzel and the valve outlet pipe line runs UPWARD toward the condensate header.
Thanks.
Thanks.
