controlnovice
Currently, we have area classification extending 10 ft away from three open top vessels (Class I, Div II), with a 3ft bubble around the openings and drains (Class I, Div I). These are interior tanks with point ventilation around the top (for adding dry material), and the building has excellent floor ventilation as well.
The plant wants to decrease the Class I, Div II area to 5 ft around the vessel (instead of 10ft). They measured all around the vessel, and even inside, at different times in the process with an LEL detector, and it never increased above 3%.
How is it explained that it is the possibility that hazardous vapors may be present so the LEL detector is not a sufficient enough test? Or is the LEL test sufficient to reduce the area classification boundary?
