cmhski
- Oct 26, 2004
- 12
Hi Everybody,
I am designing a deck w/ a 4000 lbf jacuzzi & 210 psf snow load. I end up having that each joist (@16" o.c.) bears on the 4x ledger (w/ hanger) with a total load of 1500 lbf. I want to use lags to connect the ledger to the 2x6 studs in the wall. Using the NDS ASD Table 11J (& applicable factors), I get that I need 3- 3/4" lags @ 16" o.c. That just seems ridiculous... Also, I am concerned that the large lags will cause the wood to split.
Can it be argued that it is bearing (Table 11.3.2), rather than shear that controls? Or do I need to specify a closer lag spacing w/ blocking between studs?
Thanks,
cmhski
Thanks,
cmhski
