Itayabla:
Don't worry about learning the software; it is pretty easy to use the software to the extent you need to start modeling systems. COADE has done a great job with that, and their documentation is quite good.
There is a young EIT that sits outside my office. I recently had the IT guys put CAESAR II on her machine; she was coding in isometrics within 15 minutes. (Granted...she's pretty smart...)
If you can get a hold of LC PENG's book, PIPE STRESS ENGINEERING (ASME Press), and maybe the MW Kellogg book, Design Of Piping Systems (that one might be hard to find, but as Stress Bibles go, Kellogg and Peng are the "Old Testament" and "New Testament", respectively), just study what's in there.
Learning how to enter data and hit the "Run" button in CAESAR II is pretty easy. Knowing *why* you code data into the program in a certain way is what will transition you, over time, from being a CAESAR II User to a Piping Engineer.
As for training, if your employer will let you take the 3-day or even 5-day session from COADE, I doubt that there is better training anywhere.
SNORGY.
