Hey all,
I have been running into a problem for the last few months and I am in need of some advice from the forum.
I am working in a production environment where we are using resin infusion. We are leak checking our parts for at least half an hour (with the actual requirement being 0"hg in 5min). The operators will do their leak check and measure no leaks during their leak check however during infusion they are somehow getting air into their parts. Sometimes we have discovered that there was a leak in the bag and other times we can't find a leak at all. Sometimes instead of leaking during the infusion the part will randomly begin to show streaks of air while it is sitting in the clean room waiting for cure.
All of this happens after we have leak checked the parts. We are getting at least 27"Hg at all times. What is confusing me the most is that this does not happen all the time and it never happens at the same spot while infusing. These parts have been infused, sat in the clean room for 6 hours with no leaks or air, and when we come in the next morning there will be air right through the part.
I have been thinking about the possibility of micro fractures in the composite tooling or possibly something to do with the resin/hardener mixture as it is heating up.
Any help or tips on this situation would be much appreciated!!
Thanks.
Thanks.
