347stroker
Automotive
- Sep 5, 2009
- 3
Hello all, I am building a leaf spring model Falcon for track days. The rear suspension is my big problem. Can I make the leaf spring rear into something acceptable with a watts or mumford link, or am I best off changing to the later 4 link coil spring rear end with the watts link. If I can use the lower control arms from the coil spring setup for my lower links and build a long 3rd link similar to the RRS conversions it would be a great setup I think, but am hoping for simpler answer to the problem. There is not enough room for diagonal top links attached to the diff. Would simply adding a mumford link give me a large gain in handling, close to what I would achieve with coils, or are leaf springs a lost cause?
