I have a leach field design that flows from a distribution box to drop boxes located down a hill. The leach field is installed on level ground (parallel to grade), but the drop boxes are on the hill. So, our system is to enter the drop box at a higher level than the two outlet pipes (one is for the leach field lateral, one goes to the next drop box). There is different theories as to how the flow is distributied out of the drop box.
1. flow is split equaly. Meaning 1Q enters the drop box, and 1/2Q goes to the leach field lateral, and 1/2Q goes to next drop box.
2. the outlet pipe to the next drop box is set higher than the outlet pipe to the leach field lateral. This will utilized the first leach field lateral in the system more than the other approach.
Q: Does anyone have experience or preferences of these two approaches?
Thanks, rafklm
Thanks, rafklm
