Layers
  • Thread starter Thread starter Pounce
  • Start date Start date
P
Pounce
Guest
Hey guys,
I've been searching for a few hours and can't find an answer so I thought I'ld join up here to see if anyone can help.
After creating the 3D model then creating a drawing from it, I need to be able to set layers for every aspect of the drawing.
ie. Part on one layer, dimensions on another, centre/construction lines on another etc.
I can set every thing except the part onto a specific layer, so my question, is it possible and how do you do it.
Thanks in advance
layers
simular to acad, create a drawing w/format. Using options, activate the layer toolbar. Select layer to make active, select geometry, dimensions etc.
good luck... :)
Hey guys,
Thanks in advance
As noted previous, layers work similar to ACAD. You assign a layer to an object in its propertiesmanager window. That said, why do you "need" to do this? S/W allows you to control things like color, line type, etc within the object itself, and normally the default settings are already in line with common practice. Are you trying to plot to an old pen plotter?
