Layers Question
Bester2
87
Can you copy layers from one drawing to another? If so how?
You can put them into your template.
Bradley
SolidWorks Premim 2007 x64 SP3.1
PDM Works, Intel(R) Pentium(R) D CPU
3.00 GHz, 4 GB RAM, Virtual memory 12577 MB, nVidia 3400
Bradley,
I already do that but what I am trying to do is copy the layers for each part. This is a Solidworks/ AutoCAD thing. I design everything in Solidworks then save my assemblies as a DWG file so that the designer can finalize everything. I create a layer for each part. The problem is that I have assemblies inside of assemblies. So the same parts show up on multiple drawings. I also have to ensure that the layer colors are the same so when someone pulls up the AutoCAD drawings the parts that are common to multiple assemblies appear the same. I messed around with this for a while. I thought that there may be a macro somewhere but I could not find one. My life would be so much easier if we just got rid of AutoCAD and used Solidworks only.
I do as Bradley suggested. I change the templates, then do a replace of the format in the dwg (without replacing text).
There may be a file within SW to copy layers, but I have not found it yet.
Ever users nightmare would go away if they used only one CAD software.
Creating in SW then exporting to ACAD is a sore subject for me.
Chris
SolidWorks 07 3.0/PDMWorks 07
AutoCAD 06
ctopher's home (updated 04-21-07)
