I have a layered vessel from 1959 built to the Corps of Engineers Spec. DA-23-086 ENG 59-4 Volume II or III. I have to prove the MAWP of this vessel and evaluate areas of corrosion. All I have to go by is todays ASME Sec. VIII code. Using current calculations I cannot prove the design MAWP for this vessel. My numbers are coming up a lot less than the original design. All I have to go by is a Manufacturer's drawing that is hard to read (ATTACHED). The areas of corrosion are on the layered shell. I am not sure how to address this on a layered vessel.
My vessel was originally stamped for 2800 psi and my calculations from Sec VIII are coming up just over 1650 psi. I have attached the drawing. I need as much pressure as I can get from this vessel. What can I do to get the pressure higher?
