layer management 2
mechbull
Computer
Nov 28, 2005
36
i received this message from a friend
i was asking what was wrong with my config.pro bc it had duplicated mapkeys 15 times inside
but the last thing he said was
Also, def_layer is the old school of thinking in layer management. I suggest that you setup layer rules in your start parts and get rid of the def_layers.
so my question to all of you is what is your company standards or your personal settings
this is whats in my config.pro
def_layer LAYER_AXIS axis
def_layer LAYER_SURFACE surface
def_layer LAYER_DATUM datum
def_layer LAYER_POINT points
def_layer LAYER_CURVE curve
def_layer LAYER_CSYS csys
def_layer LAYER_QUILT quilt
Mechbull,
Here is a great thread on layers thread554-137512 if you need more do a search on this forum. Best of luck
Best Regards,
Heckler
Sr. Mechanical Engineer
SW2005 SP 5.0 & Pro/E 2001
Dell Precision 370
P4 3.6 GHz, 1GB RAM
XP Pro SP2.0
NIVIDA Quadro FX 1400
o
_`\(,_
(_)/ (_)
"Coming together is a beginning, staying together is progress, and working together is success." - Henry Ford
mechbull-
I'm using WF 2 and am getting the same thing; I keep getting multiple definitions of the same mapkey in my config.pro. Essentially, the Delete, Modify, Update functionality in the mapkey utility seems to be dysfunctional.
Tunalover
tunalover im still getting it too, usually after i add a new mapkey and shut down the next day it has multiplied i have posted this ont ptc's forum and waiting for a response will update post when i have any answer from them
