Launching SolidWroks from the Command Line
jwalz
Computer
Is there a way to launch SolidWorks from the command line? I have an Access database with lists of drawing files in it. I want to be able to have a user click on the drawing name and have solidworks open the file automatically.
My VBA code currently looks like this:
Private Sub DrawingName_DblClick(Cancel As Integer)
'Open solidworks with the appropriate drawing
strFilename = Me.DrawingFile
x = Shell(strFilename, 1)
End Sub
But I get an error message that says "invalid file or procedure call." The file name variable contains the full path information. Can anyone tell me what I am doing wrong or make suggestions?
Thanks,
Janet
As I understand it, shell is used to activate applications.
I once saw some code to open a file with its default application, but I can't seem to find it. If I run across it I will post.
In the meantime, try using shell to open the SW, then access the SW application object via CreateObject and use it to open the file via SW API.
[bat]All this machinery making modern music can still be open-hearted.[bat]
Yes, that's the one. If you use the "Open" verb as its verb parameter, ShellExecute will use the same command-line type of default behavior that you get when you do a right-click Open on the filename from Windows Explorer. (You can see the syntax for these command lines in the registry)
Remember to declare the functions you will be using:
Private Declare Function ShellExecute Lib "shell32.dll" Alias _
"ShellExecuteA" (ByVal hwnd As Long, ByVal lpszOp As _
String, ByVal lpszFile As String, ByVal lpszParams As String, _
ByVal lpszDir As String, ByVal FsShowCmd As Long) As Long
Private Declare Function GetDesktopWindow Lib "user32" () As Long
Const SW_SHOWNORMAL = 1
And then you can make use of the function something like this:
Scr_hDC = GetDesktopWindow()
StartDoc = ShellExecute(Scr_hDC, "Open", sDocName, "", "C:\", SW_SHOWNORMAL)
Brenda
That worked perfectly. Thank you both very much!
Janet
