lathe thread-cutting dial 1
thereg64
I have an old lathe in the machine shop, which has an indicator dial that has dual numbers. However, the machine is so old no documentation can be found inhouse and/or online. Have tried to contact mfg'r with no avail. Anyone wanna take a shot in breaking the code? Will upload photos tomorrow
lathe will do both, metric and imperial
When in doubt, mark the dial with a marker and use the same position to engage each pass. Does it have a quick change gearbox that is marked with the available pitches, or is it a change gear system?
A photo would speak volumes.
Go over to the local trade school and find the oldest machining teacher you can they will probably know -- if that fails find out who just retired and they will probably consult for a pub lunch.
I have a lathe from the early 40s,and one from 52, they are from two co. one has 12 no. the other is 10, the rule is
Odd number of thresds, you can lock in on any number, Even number only use the even numbers, 2,4,6 ect, has worked well for me for the last 35+ yrs.
SBI
Central Ne.,USA
Tony at has a pretty big library of manuals and the like. Might be worth a call.
image.php
