In Section F1 of the Allowable Stress Design manual, Lb is specified as the laterally unsupported length of the compression flange.
One of the weaknesses I see in the AISC is that I cannot find any guidance on what this length actually is in situations more complicated than a simply supported beam.
For instance, in the beam diagrams and formulas for various static loads, pages 2-296ff, using Example 15, "Beam Fixed at Both Ends-Uniformly Distributed Loads" as an example and assuming that there are not intermediate flange braces between the two supports:
For the bottom flange:
Is Lb = 0.2113*L (i.e. the length away from the support and the middle part of the flange that is tension provides the restraint to the part that is in compression) or is Lb = L (the length between actual physical restraints)?
Similarly for the top flange:
Is Lb = (1-2*0.2113)*L (i.e. the length of the top flange that is in compression) or is Lb = L?
I would appreciate hearing what others believe to be the correct interpretation and also any reference within AISC or elsewhere that justifies their belief.
