Geotechnical76
I understand that Broms method for laterally loaded piles assumes a constant subgrade reaction along the pile section. In cohesive soils, Broms assumed that the soil flows around the pile and based on that he assumed that the ultimate soil resistance will be [9(Su)(D)] (nine times the undrained shear strength times the pile diameter).The above estimate is good for short rigid piles.
The py curve method can be used for both short and long piles.
When the calculations from the py method and the Broms method are compared, results show large differences. For example, the Broms method suggested 15 feet of embedment to resist the lateral load while the py curve method suggested 33 feet. Concrete piles of 42 inches where used to resist lateral load of 50kips in medium stiff silty clay (cohesion=1000 psf).
Thanks.
Thanks.
