mikesg
- May 26, 2006
- 49
Hallo community,
I am working on a single level structure that consists of a system of moment frames (braced in longitudinal direction). The roof is covered with trapezoidal sheeting supporterd directly on the beams of the frame (on the top flange).
The sheeting is placed in such a way that the orientation of the ribs (its stiff direction) is transverse to the beam.
I want to know the extent to which I can rely upon this sheeting for providing lateral support to the top flange of the beam and the design checks needed to choose the fasteners between sheeting and beam that will transfer the forces providing such extent.
Should I design for a percentage (say 2%) of the force in the flange distributed between all fasteners? Now should I go for checking whether the in-plane stiffnes of the sheeting is sufficient for providing a bracing (as described in Yura's "Fundamentals of beam bracing")?
Also, in case I can rely upon this lateral bracing support should I provide additional torsional bracing for the beam?
Many thanks,
Mike
Many thanks,
Mike
