1
- #1
Folks,
I have a lateral stability problem that keeps appearing in front of me.
When looking at simple 2 storey housing of typical construction I would normally assume that any wind load on the front/rear walls is transmitted to the gables via diaphragm action of the timber floor. Also, any wind load on the gables will be transferrred to the front and rear walls by the same mechanism.
However, when steps are introduced in the floor panel (say from gable to gable along the centre of the dwelling parallel to the front wall), my logic of transferring all of the wind load down to foundation breaks down. The floor is then split up into 2 seperate diaphragms. When behaving as horizontal deep beams, the front diaphragm spans from the front shear wall to the step in the floor. The rear diaphragm spans from the rear shear wall to the same step in the floor.
By my reckoning, I require some form of lateral stability at the step in the floor. This could be provided by an additional wall or possibly a steel/concrete frame. The wall option doesn't always suit the layout and the frame option appears to be an overkill for simple 2 storey house construction.
Could anybody confirm that my logic is correct and, if so, provide me with any other solutions that they have used for this case of the stepped floor as I'm sure it's quite common.
