I have designed a single story steel frame structure with metal stud infill. I used threaded rod cross bracing to resist lateral loads. The contractor comes back and request that we use shearwall system. I'm having trouble getting the lateral load from the diaphragm (metal deck) into the shearwall without turning the stud infill into a gravity loadbearing system (connection from top of wall to beam to deck). I think one option would be to ensure that all dead load be in place before attaching the sheathing. The only problem is selecting a transfer mechanism from the deflected beam (gravity) to the wall below (lateral stability). Any help on this would be greatly appreciated.
