I'm working on an analysis of an existing drilled shaft in SM soils (frost susceptible), where overturning is the governing criteria, not end bearing.
The existing drilled shaft terminates 9 feet below ground surface and frost depth is 5 feet below ground surface. When I neglect lateral resistance below frost depth this foundation is failing, big time.
I'm afraid to recommend removing any existing soils to place an "insulating" layer of materials less susceptible to freeze-thaw/seasonal variations, because 1) there is an existing structure adjacent to the one I'm considering. 2) I'm concerned that removing any existing soils would worsen the conditions and reduce my lateral resistance.
All of my resources specifically say that you should bear below frost depth, which this criteria has already been met. Does anyone have any reliable/credible resource(s) that includes soils above the frost depth for lateral resistance?
Intuition tells me that there should be some resistance, though it should probably be reduced. Thanks.
