Please refer to attached illustration for building layout with proposed addition. The addition is small so the additional lateral load is insignificant, and the sidewall is lengthy for absorbing the load, but the existing building is c. 1880 brick construction, in good condition. (Your typical small town main street building). I have sketched a suggested connection using threaded rod penetrating thru the existing wall and fastened to the inside with a large steel plate and nut. The owners are keen on the industrial look of the exposed steel plate, painted black. I am proposing a total of four rods - two along the bottom chord, and two along the top chord to maintain stiffness.
Just looking to get some input from others who may have more experience with transferring lateral loads into existing brick. Any info you can provide is appreciated.
-Troy
-Troy
