To simplify the structure I'm designing, lets say it is a steel framed 100' x 40' x 22' tall building. Each wall is CMU. Using CMU walls as shear walls can lead to cracking in the CMU (since to act properly, CMU shear walls crack). Instead, I'm forced to use moment frames. The lateral deflection limit is going to make a large difference in my design. I have several questions on it.
1) In IBC table 1604.3, deflection limit for wind for exterior walls with brittle finishes is L/240. That seems like a low limit for CMU. The allowable deflection would be 1.1". ACI 530 doesn't give a deflection limit. Is L/240 the correct deflection limit for CMU walls?
2) Other engineers in my office use the L/240 limit for lateral deflection. However, they calculate it in an interesting way. They say that the building acts like half of a beam. "The top of the wall is equivalent to the midpoint of a beam." Saying this, you could say that to properly use a deflection limit of L/240, you'd have to double the building height. Or, in other words, use L/120 for the lateral deflection. They have used this same concept for cantilevers. I can understand their reasoning, but have been hesitant to use this method, because I'm not sure what the IBC intends. My gut feeling is to not use this method, and we know what they say about gut feelings.
-I'm thinking of using L/240 (true L/240), and on my CMU wall braces from the steel beams, detailing them so that the steel frames can move without moving the wall or creating a stress in the brace or wall.
Thanks in advance for the feedback.
