JonathanEngr
I'm a civil/environmental engineer by trade, but had the typical structural and steel design courses during my course of study--just enough to be dangerous! I have a friend I'm trying to assist who is wanting to span an area roughly 50 feet in length with a pedestrian bridge capable of handling typical pedestrian loads an possibly a small riding mower from time-to-time (he's essentially joining two pieces of property via a bridge). I did a rough estimation on the steel required trying to keep it in the realm of "typical" sections. I came up with a max moment of 13.88 kipft, which will be supported by three 50-foot w8x13 steel sections (to keep my deflection less than L/360) braced every 12.5 feet allowing a max load of 17.84 kipft. My questions are... would I be better served to resize this for two steel beams? The bridge will only be 5-6 feet wide. Secondly, exactly how should I go about laterally bracing these pieces of steel? Do I need to utilize diagonal bracing, or will welding a steel piece perpendicular to each piece of steel every 12.5 feet suffice (does anyone have a good detail/sketch for lateral bracing?). Lastly, I told him to use treated wood as decking, but since I'm not familiar with bridge decking tie-ins I'm not sure what the best way would be to tie the boards to the steel sections (I'm also wondering what the best way to tie the railing to the steel would be, as well). Any suggestions? Thanks in advance!
