Ill check out some of the links above. Some of them, I already have. Thanks for the responses and Ill post what I found.
Here is more info.
range - 0 to 8'
pressure - atmospheric
humidity - 100% desired but likely hard to find w/o paying way to much
acceleration - really slow
speed - perhaps 6"/minute
accuracy - +-0.25%
linearity - 0.1%
one time calibration at set-up not start-up, in other
words, we would set the zero and span when we install
the unit for the first time and it would have non-
volatile memory
retroreflective should fit on top of a 3" diameter shaft where weight is not an issue (I thought all these were basically plastiv).
