I am trying to find an alternative to machining a slot through a steel nut using a slot mill.
Can anyone tell me if this would be possible to achieve using laser cutting, and point me in the direction of equipment that may be capable of this.
The nut is M16, 24mm accross flats. I need to find the diameter capability and depth capability of the relevant machniery if this is possible.
Many Thanks,
Matt.
