May 28, 2018 #1 Lars1978 Mechanical Joined Dec 30, 2015 Messages 327 Location NL Hi All, Can anybody tell me how to import a .las file into NX12 ? This las file is the output of an 3D scanner. Lars Lars NX12.0.1.7 native Solid Edge ST10 Inventor
May 28, 2018 #2 NutAce Mechanical Joined Apr 22, 2010 Messages 1,192 Location CH Don't think that NX is capable of doing this. Most 3D scanners however should be able to generate an STL file. This is no problem for NX to import. Or you need to find an online translator for .las to .stl Ronald van den Broek Senior Application Engineer Winterthur Gas & Diesel Ltd NX9 / TC10.1.2 Building new PLM environment from Scratch using NX11 / TC11 Upvote 0 Downvote
May 28, 2018 #3 Toost Mechanical Joined Jan 18, 2011 Messages 3,009 Location SE There is a "steinbichler" import. If i understand it correctly, that is a common 3d scan format. Regards, Tomas Upvote 0 Downvote
May 29, 2018 Thread starter #4 Lars1978 Mechanical Joined Dec 30, 2015 Messages 327 Location NL Hi All, Please find the .las file attached. (see link) I've found a converter which translates the .las file into a point cloud. (LAStools) To import this file (.txt) takes a long time. Which genius can help me to make a usable .stl file out of the .las. https://www.dropbox.com/s/6cwokniwfmyg4mr/files.zip?dl=0 Lars Lars NX12.0.1.7 native Solid Edge ST10 Inventor Upvote 0 Downvote
May 29, 2018 Thread starter #5 Lars1978 Mechanical Joined Dec 30, 2015 Messages 327 Location NL Tomas, What do you mean with a steinbecher import? Is this an extra NX module? Lars Lars NX12.0.1.7 native Solid Edge ST10 Inventor Upvote 0 Downvote
May 29, 2018 Thread starter #7 Lars1978 Mechanical Joined Dec 30, 2015 Messages 327 Location NL Tomas, Don't think this is the solution. This translater asks for .ac files.... Lars NX12.0.1.7 native Solid Edge ST10 Inventor Upvote 0 Downvote
May 29, 2018 #8 Toost Mechanical Joined Jan 18, 2011 Messages 3,009 Location SE I was rather hoping that your scanner could output a steinbichler file instead of .las Regards, Tomas Upvote 0 Downvote
