large threads
landrover77
40
i need to draw a part which is essentially 6 threads running along the axis of a large cylinder. I have the equations for the threads and the wrap angle(how far it goes round the cyliinder) could someone please help me. Simple help would be great.
You have to create these threads with a Helix-based feature. Look in SW Help for "helix" and that should get you on your way.
You should only have to model 1 thread, then revolve that feature around your cylinder for the other 5.
Ray Reynolds
"There is no reason anyone would want a computer in their home."
Ken Olson, president, chairman and founder of Digital Equipment Corp., 1977
Have you read faq731-376 to make the best use of Eng-Tips Forums?
Are the "threads" a contiguous part of the cylinder or are they going to be attached (bolted or welded) to the cylnder in an assembly?
Either way it sounds like you need to use a Sweep. There is a fair amount of good information in the Help files under "Sweep" and also in the On-line Tutorial in 3D Sketching & Revolves & Sweeps.
Basically you need to create the path of the sweep with a helix and a profile of the thread on a plane perpendicular to to the end of the helix. There is a section in the help files which relate specifically to the end conditions of the swept profile.
If the "thread" is to be a part in an assembly, model it seperately, add it to the assy, then create a Circular Pattern
[cheers] from (the City of) Barrie, Ontario.
[lol] If everything is going well, you have obviously overlooked something [lol]
- At the bottom gives an example of threads.
Scott Baugh, CSWP [borg2]
faq731-376
