Hi All.
This is my first post on this site so i hope it is in the right section.
I have been given the task to desgin footings for a 20 storey building which sits on rock (Approx 6000kPa bearing).
I have had no trouble with pad footings for the columns however i am now to design the footing for the core and am not quite sure where to start.
This footing has the core, two shear walls either side and two columns that land on the same footing. I have attached a simplistic paint drawing of what it is to look like. (refer to attached picture)
I have already obtained the moments and axial loads for each element and am now unsure of where to go from here.
My feeling would be to treat this as a one way slab (upside down) and design however being a core and shear walls would there not be uplift etc... concerned with wind and earthquake load cases.
Any help would be greatly appreciated.
Cheers,
Cheers,
