Dear all,
Given a circular opening in a torispherical head. The opening is large, but within the spherical part of the head. The nozzle is inserted through the head - no internal projection (flush with the internal side of the plate). The nozzle wall is so thick, that it forms the flange for a flat end cover with a ring gasket. Tapered holes for bolting and a grove for the gasket are machined into the "nozzle wall".
Question No. 1
Can the material in the nozzle wall outside the head used in the reinforcement calc. for the opening be consider in the flange calculation - or should the flange be assumed starting where the reinforcement is no longer considered (2.5 times head WT out from the head surface) thus avoiding overlap of areas?
Question No. 2
Does ASME VIII Division 1 allow FE analysis of this construction.
Question No. 1
Question No. 2
