jonesey
- Oct 6, 2002
- 60
We have the requirement for a 42" diameter overhead line from a 50m high vacuum tower. Our required piping materials specification only goes up to 36" and needs to be expanded to 42". We use graphite reinforced stainless steel flat ring gaskets normally in this material spec. Someone has raised the question of wouldn't a graphite/stainless steel spiral wound gasket, with inner and outer ring, be better in this application. AS i have no experience in lines of this size, can anyone advise ?
