edu704
- Aug 5, 2010
- 1
I work in a downstream company and I was requested for a project a large diameter tank. Nominal cap. aprox 75,000 cu.meter. For that, the total volume would be 84,000 cu. meter. Because of local regulations, the distance to nearby buildings is limited to 2D. So, the max. diameter is 63 m (207 ft). For that diameter, the height would be approx 27 m (89 ft). The issue is that bottom thickness shell would be more than 1.5" (A516 Gr 70 material), and I think that is difficult to fulfill the the preheat requirement in the field for that dimensions. Does anyone have any recommendation ? Thanks,
