I am looking at a fairly large canopy (19 ft x 18 ft) that cantilevers out from a building and is supported at the ends by a chain running back to the wall (about 9 ft up from the canopy).
Three questions:
1) Does anyone have a chain supplier that has large (14000 lbf working load or higher) chain that will handle being outdoors?
2) For the possiblity that the chain would need to be rigid (i.e. the case of wind uplift), has anyone found / used larger chain that has the links welded and if so, can you point me in the right direction?
3) Are there any suggestions that would provide the large chain "look" while acting as a rigid link for uplift?
ZCP
Three questions:
ZCP
