Metehanbektas
Automotive
I faced with an application, in which laminar piston rings are used on the piston. Normally, they are used in combustion engines. It's a normal hydraulic cylinder application, but extracts out relative faster around 15 m/s. Seals may heat very fast. Is it the reason why laminar ring is used, instead of normal NBR or FKM seals ?
Link
Link
