Label Point in Drawing per Point Name
rickyt
Automotive
Jun 26, 2002
240
If Catpart has points labled as "1234cmm001", 1234cmm002, etc. the points in the drawing become "generated points".
I need to label a bunch of points in a isometric view, per their point name. Is there a command that I can use to identify which point was projected to generate this "generated point", or is there a command/macro similar to coordinate dimension that would label the point with leader attached?
Thanks,
Rick
