Kremser Brown equation - Gas absorbers
georgeverghese
Chemical
AU
In a simplified version of this equation, we have :
Fraction of solute in exit gas as a ratio to that in the incoming gas = (A-1) / ((A^(N+1)) - 1)
Where the LHS = y2 / y1 in this simplifed form of the KSB equation ( which is valid for low values of y, and low values of the same solute in the feed lean solvent, and absorption is more or less isothermal)
Where y2 = solute mole fraction in exit gas ; y1 = solute mole fraction in incoming gas
A = absorption factor ; N= no of theoretical stages
There is an alternate presentation of this KSB equation which give N explicitly without going through a trial and error calc.
Does some one have the explicit alternate presentation for A? Thanks in advance for sharing.
Yes, the absorption factor is constant in these cases.
These attachments provide the value of N explicitly, while I am looking for the expression that gives A explicitly.
In a lean oil absorption tower, or a TEG tower, once the value of A is known for a given set of operating conditions (say from a process simulation), it is possible to rate the tower for more trays or less trays and determine the change in exit gas solute concentration.
Getting the value of A for a known set of operating conditions is the reason for this search for an explicit expression for A - it avoids the tiresome trial and error method to get this value.
