We are a leading manufacturer of motion, acceleration and impact switches. Typically, these devices are built in transistor packages (TO-18, TO-5, etc)Some time back, someone decided to switch from Kovar to C1215 for headers, in an effort to reduce costs. However, we use nickel cans and have encountered weld spatter problems (resistance welding, Benchmark welders). Since these devices must be absolutely free of contamination, loose particulate spatter is a serious problem.
I am trying to convince management that returning to Kovar is the best solution, as its low resistivity and molten flow characteristics are clearly better than C1215. Comments or suggestions from those with greater experience with Kovar/nickel welding would be of great use.
Thanks,
GSwitch
Thanks,
GSwitch
