PLCwantaBe
Industrial
- Nov 6, 2009
- 4
I'm trying to program the analog inputs using Moeller Easy-Soft6 software on an Easy819 controller. I want to controll the distance that the cylinder can extend/retract, using it's internal linear scale(24VDC excitation/0-10VDC signal). I connect my return signal voltage to inputs 7,8,11 or 12 stated by manual for analog inputs. Using the Analog comparator/threshold value switch, how do I program the parameters to set my limits for the cylinder. The cylinder has a 4" stroke length and my first limit will be the Home position (0 volts). Second position is 1"=2.5volts from the Home and third position is 3"=7.5volts from Home. Has anybody used this software and programed the analog inputs before?
