Hi Corus,
I am applying tie constrain on two surfaces of my cube, but i am getting these warning,
Would you please help me why i am getting these warnings
For *tie pair (assembly__pickedsurf264-assembly__pickedsurf263), adjustment was specified but no node was adjusted more than the adjustment distance = 2.22000e-16.
Slave node 1 instance unit cell-1 will not be tied to the master surface assembly__pickedsurf263. The distance from the master surface is greater than the position tolerance value.
Slave node 8 instance unit cell-1 will not be tied to the master surface assembly__pickedsurf263. The distance from the master surface is greater than the position tolerance value.
Slave node 9 instance unit cell-1 will not be tied to the master surface assembly__pickedsurf263. The distance from the master surface is greater than the position tolerance value.
Slave node 10 instance unit cell-1 will not be tied to the master surface assembly__pickedsurf263. The distance from the master surface is greater than the position tolerance value.
609 nodes are either missing intersection with their respective master surface or are outside the adjust zone. The nodes have been identified in node set WarnNodeMissMasterIntersect.
thanks
