Kilos as pressure unit?
nedhalnooh
3
At a poultry slaughterhouse, a cage washer has the following pump requirements:
- flow: 40 m3/h
- pressure: 3.5 kilos!!!
- power outlet: 5.5 kW
The manufacturer is a Dutch company.
What does "kilos" mean here? Do they mean kgf/cm2?
That is the only reasonable assumption (although there is nothing reasonable about kgf or about kgf/cm^2). I'm really not sure what the driving force behind imposing another unit of measure, especially since 1 kgf/cm^2 is 1.019 bar so what the heck do you gain?
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
Exactly! And the irony is that we end up making "assumptions" in "specifications"!!!
Actually I wouldn't make such an assumptions based on the presence of "kilo" in kgf/m2. My assumption was based on the characteristic curve of the existing pump (unfortunately not the original) which has gives a head of 35m at optimum efficiency. 35m head is equivalent to 3.5 kgf/m2.
Contact the cage manufacturer for more details about the unit. Never assume as it makes an A__ out of you and me.
Using it as kg/cm2 (quite a common way of expressing pressure for some reason in mainland Europe) gives you 5.5kW shaft power for the flow and pressure stated, so I think it's a fairly safe assumption, but note somewhere in writing that it is an assumption to cover yourself.
My motto: Learn something new every day
Also: There's usually a good reason why everyone does it that way
Is the pump specification from the owner's manual? If so just attached that page so that we can look at it.
