ddelaiarro
I have the following set-up:
A gear is mounted to a ferrofluidic feedthrough (vacuum to atmosphere seal that allows rotational motion to be transmitted via a ferrofluidic vacuum seal). A shaft (1.5"-2.0" diameter) travels through the axis of the gear and also moves 0.875" up and down.
I need to transfer the torque from the gear to the shaft. I'm thinking I can put a key on the gear and a keyway in the shaft. Does anyone have any literature on a situation like this? I'm looking for information on recommended materials, design, tolerances, etc. I want backlash to be minimal, but, at the same time, I don't want to cause too much drag on the linear portion of the motion.
Thanks in advance for any help.
Dan
Dan
