I have some mini-greenhouse structures in which the humidity is controlled by atomizing misters. The misters operate by positive air and positive water pressure. Air and water solenoids open and close as needed to maintain a set point. Our air is supplied by an air compressor, which works just fine at maintaining a constant 50 psi or so. Our water supply, however, comes from a well that is shared by other facilities. So, depending on the demand at the time, our water supply pressure will vary between 25 and 75 psi. I would like to maintain 50 psi. I know I could install a holding tank and use a pump with a regulator, but I was hoping for something simpler. Can I use a booster pump continuously, and have it recirculate exess water back into the inlet? If not, what ideas would you have?
Thanks!
Sam
Thanks!
Sam
