Situation:
Existing culvert is fairly over capacity. Watershed is 600 acres of mostly undetained urbanized and suburbanized watershed. FIS says there's 480 cfs in it at the 100 year storm. This causes a pretty big head differential across the culvert - upstream head is about five feet above the downstream head, which lends me to believe the thing is inlet control for the 100 year event.
My development is just upstream of this culvert, and my land plan really lends itself to putting by stormwater management system, which will be an underground concrete vault with an offline cistern, at an elevation well below the 100 year elevation upstream of the culvert. But we're close enough to the culvert that I have the opportunity to not discharge into the creek at all, and carry my discharge into the street, dog-housing the culvert and dropping my water in downstream of the head wall that's pretty clearly forcing the thing into inlet control.
What tailwater depth should I assume in this design, for my stormwater management system? Seems to me, unless I'm thinking about this wrongly, that I should be able to calculate the 100 year HGL in the pipe and use that as a tailwater. Right? Am I missing anything?
The flood profile on the FIS doesn't really show it that way. I'm not sure how they generated the drawing, but it shows the HGL for the culvert being high through the whole culvert, and only dropping off after the downstream headwall. Graphical error in the FIS maybe? (profile attached - Hermance Drive is the culvert in question)
Unfortunately, the FIS was done in XP-SWMM instead of HEC-RAS so I can't easily get at the guts of their model.
Disclaimer: I haven't had my coffee today.
Hydrology, Drainage Analysis, Flood Studies, and Complex Stormwater Litigation for Atlanta and the South East -
