GasProcess
Petroleum
There are two pumps for lifting sea water for cooling purpose. ( One running + one standby ). Recently we have replaced the pump shaft for for Sea Water service from SS to K-Monal. The new shaft indicated signs of light pitting when pump was kept idle for about 8 months in the water. Is this ok or some thing wrong with shaft material.
The original Shaft material for the same pump was some grade of SS which is as good as new even after many years of service under same conditions.
