JT viewer for NX assembly in TCE
ashivu123
Aerospace
How to add JT viewer for NX assembly in TCE?? I did below method though its not showing up in JT preview.
1. Toggled on 'Save JT preview' in NX assembly. (JT viewer is not created).
2. Export=>JT..from NX and than imported as direct model in item revision (JT model is created however its no showing up in JT preview)
Saving JT is working for piece parts however its not woking for assembly.
JTs are created from the model reference set (i.e. for modelled parts).
Assemblies in Vis work the same way as they do in NX, by collecting together JTs of components.
So you need to select the BOMView in TC, and view that in your viewer, which will then load the components.
NX 8.5 with TC 8.3
That works, My intent was to add JT viewer in item revision so that user can see JT preview if the dont want to direct to the structure manager.
