jpg on a drawing
  • Thread starter Thread starter kc1876
  • Start date Start date
K
kc1876
Guest
how do I put a jpg on a drawing?
With the drawing open, select Insert > Object... Choose to Create from file. Find your file and hit OK.
i see no object option under my insert pull down. what rev of Pro are you using?
Which are proe version are you working on?
2001 2002350
Select: Insert>Object>Create From File>Browse
The Object command under the Insert pulldown does not exist on Sun Unix for Pro/E 2001. At least it doesn't for me. Any ideas why this may be?
jbland,
So your menu pull down doesn't look like this...
It may be related to the fact that you're running on a Unix box thought I don't quite see why. I'm running 2001 build 2002140 on Win2kPro.
it wouldnt surprise me at all if it were a unix issue. nuff said. i have nt's available to me.
