Journal to select drafting view 2
niedzviedz
307
I wanna create journal to select drafting view and then toggle between hidden lines invisible or dashed.
I create some code, but I need help.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module Module1
        Dim theSession As Session = Session.GetSession()
	Dim ui As UI = UI.GetUI()
	Dim ufs As UFSession = UFSession.GetUFSession()
    Sub Main()
        If IsNothing(theSession.Parts.BaseWork) Then
            'active part required
            Return
        End If
        Dim workPart As Part = theSession.Parts.Work
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim theDrftView As Drawings.DraftingView
	Dim response1 as Selection.Response = Selection.Response.Cancel
start1:
        response1 = SelectDraftingView(theDrftView)
        EditView(theDrftView)
end1:
    End Sub
    Sub EditView(ByVal thedrafview as drawings.DraftingView)
	Dim markId3 As Session.UndoMarkId
	Dim dimname1 As String = Nothing
        For Each selectedView As View In theDrftView
            dimname1 = selectedView.ToString()
		If dimname1.Contains("projected") = True Then
		   Dim projectedView1 As Drawings.ProjectedView = selectedView
		   projectedView1.Style.HiddenLines.HiddenlineFont = Preferences.Font.Invisible
		   workPart.DraftingViews.SuppressViewBreaks(projectedView1)
                   projectedView1.Commit()
		   workPart.DraftingViews.RestoreViewBreaks(projectedView1)
		end if
	Next
        Dim nErrs1 As Integer
        nErrs1 = theSession.UpdateManager.DoUpdate(markId3)
    End Sub
    Function SelectDraftingView(ByVal prompt As String, ByRef selView As Drawings.DraftingView) As
Selection.Response
        Dim theUI As UI = UI.GetUI
        Dim title As String = "Select a drafting view"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim cursor As Point3d
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim selectionMask_array(0) As Selection.MaskTriple
        Dim selObj As TaggedObject
        With selectionMask_array(0)
            .Type = UFConstants.UF_view_type
            .Subtype = UFConstants.UF_all_subtype
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _
         title, scope, selAction, _
         includeFeatures, keepHighlighted, selectionMask_array, _
         selObj, cursor)
        If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then
            selView = CType(selObj, Drawings.DraftingView)
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
I receive an errors: (I translate it to english, so there maybe some misunderstanding)
[ul]
[li]line 28 - There is no arguments for selview [/li]
[li]line 28 - You cannot convert from type nxopen.drawings.draftingview to string [/li]
[li]line 41 - draftview is not declared [/li]
[/ul]
With best regards
Michael
Your SelectDraftingView function requires two arguments to be passed in, you have only provided one argument. Fixing that should take care of the first two errors that you are getting.
For the second error, my guess is that you have misspelled the variable name in either line 41 or line 36; perhaps they should match?
www.nxjournaling.com
Thanks for help. I mixed Your code from Link and with some code I have to select dimensions and then apply tolerances to them. After fixing it I received another error:
line 41 - expresion is type of "NXOpen.Drawing.DraftingView" which is no the type of collection (sorry for translation :) )
With best regards
Michael
Ok, I made some changes, now I don't have any error until I select a view.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module Module1
    Sub Main()
            Return
        End If
        lw.Open()
	Dim DRWVIEWS as Drawings.DraftingViewCollection
start1:
        response1 = SelectDraftingView("select drafting view", theDrftView)
end1:
    End Sub
    Sub EditView(ByVal theDrftView as drawings.DraftingView)
        For Each selectedView As View In DRWVIEWS
		end if
	Next
    End Sub
    Function SelectDraftingView(ByVal prompt As String, ByRef selView As Drawings.DraftingView) As Selection.Response
        End With
         selObj, cursor)
        Else
        End If
    End Function
    End Function
End Module
After I select view I receive an error:
[li]System.nullreferenceexception: Object reference not set to an instance of an object (...) line 43 [/li]
Also this selection method allow me to select only one view, but I wanna select multiple. How to fix it?
With best regards
Michael
You get a null reference exception on line 43 because DRWVIEWS is declared as a drafting view collection object, but it needs to reference a specific instance. However, it isn't necessary at all in your code. Since you are passing in a reference to a view that you want to change, simply use the view reference that you pass in, there is no need to iterate through a view collection. Eliminate the 'for each' loop and the DRWVIEWS variable then just operate on the view that you pass in. Once you get it working for a single view, you can then change the code to work with multiple views.
Ok, now the whole sub looks like this:
Code:
        dim selectedView As View
		end if
	'Next
But I still get null reference error.
With best regards
Michael
Change this
Code:
to this
Code:
dimname1 = theDrftView.ToString()
then you can get rid of the unnecessary selectedView variable.
Thanks, that solved some problems, but how to rid of selectedview?
With best regards
Michael
Ok, I solved it. Now I would like to select more than one view. How to do this?
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module Module1
    Sub Main()
            Return
        End If
        lw.Open()
start1:
end1:
    End Sub
        'lw.WriteLine(dimname1)
        'lw.WriteLine("view selected: " & theDrftView.Name)
		If dimname1.Contains("ProjectedView") = True Then
		   Dim projectedView1 As Drawings.ProjectedView = thedrftview
		end if
		If dimname1.Contains("BaseView") = True Then
		   Dim baseView1 As Drawings.BaseView = thedrftview
		   baseView1.Style.HiddenLines.HiddenlineFont = Preferences.Font.Invisible
		   workPart.DraftingViews.SuppressViewBreaks(baseView1)
 		   baseView1.Commit()
		   workPart.DraftingViews.RestoreViewBreaks(baseView1)
		end if
		If dimname1.Contains("SectionView") = True Then
		   Dim sectionView1 As Drawings.SectionView = thedrftview
		   sectionView1.Style.HiddenLines.HiddenlineFont = Preferences.Font.Invisible
		   workPart.DraftingViews.SuppressViewBreaks(sectionView1)
		   sectionView1.Commit()
		   workPart.DraftingViews.RestoreViewBreaks(sectionView1)
		end if
	'Next
    End Sub
        End With
         selObj, cursor)
        Else
        End If
    End Function
    End Function
End Module
With best regards
Michael
In the SelectDraftingView function you will need to use the .SelectTaggedObject[highlight #FCE94F]s[/highlight] function rather than the .SelectTaggedObject function. This will require you to declare an array of objects and pass it in to your updated selection function. Then edit the EditView subroutine to accept and process an array of drafting views.
p.s. your EditView subroutine can be simplified to this:
Code:
		   theDrftView.Style.HiddenLines.HiddenlineFont = Preferences.Font.Invisible
		   workPart.DraftingViews.SuppressViewBreaks(theDrftView)
                   theDrftView.Commit()
		   workPart.DraftingViews.RestoreViewBreaks(theDrftView)
    End Sub
Thank @Cowski.
I changed the code to this:
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module Module1
    Sub Main()
            Return
        End If
        lw.Open()
	Dim selectedviews (-1) As TaggedObject
start1:
        response1 = SelectDraftingView(selectedviews)
        EditView(selectedviews)
end1:
    End Sub
    Sub EditView(ByVal selectedviews () As TaggedObject)
        For Each selectedview as view in selectedviews
	next
    End Sub
    Function SelectDraftingView(ByRef selobj() As TaggedObject) As Selection.Response
	Dim resp As Selection.Response = Selection.Response.Cancel
        Dim prompt As String = "Select a drafting view"
        Dim message As String = "Select a drafting view"
        Dim title As String = "Selection"
        End With
         resp = theUI.SelectionManager.SelectTaggedObjects(prompt, message, scope, _
                selAction, includeFeatures, keepHighlighted, selectionMask_array, selObj)
 '           selView = CType(selObj, Drawings.DraftingView)
        Else
        End If
    End Function
    End Function
End Module
But after I select the view and click OK i receive an error "null reference exception" line 46. I also commented line 84, because I get an error too. Any suggestions what I done wrong?
With best regards
Michael
The signature of a "For Each" loop looks something like this:
Code:
For Each tempVariable as Type in Collection
A For Each loop processes each item in the specified collection; the tempVariable holds the current item from the collection. That means that inside the loop, we need to use the tempVariable to reference the current item. In the case of your code, you have named the temporary variable seledtedview; therefore, your code should look something like this:
Code:
   selectedview.Style.HiddenLines.HiddenlineFont = Preferences.Font.Invisible
   workPart.DraftingViews.SuppressViewBreaks(selectedview)
   selectedview.Commit()
   workPart.DraftingViews.RestoreViewBreaks(selectedview)
next
I tried this, but I've got an error "element "style" is not a member of NXopen.view" and "element "commit" is not a member of NXopen.view" so I changed code to shown above.
With best regards
Michael
You've specified selectedview as the wrong type. Instead of "view", it should be "Drawings.DraftingView" as in your previous code.
Thanks @Cowski for your support. Below is my final code, maybe it will be useful for someone. It toggle between invisible / dashed lines.
Code:
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Module Module1
    Sub Main()
            Return
        End If
        lw.Open()
start1:
end1:
    End Sub
	Dim status as string
        For Each selectedview as Drawings.DraftingView in selectedviews
		   if selectedview.Style.HiddenLines.HiddenlineFont = Preferences.Font.Invisible then
		   selectedview.Style.HiddenLines.HiddenlineFont = Preferences.Font.dashed
		   elseif selectedview.Style.HiddenLines.HiddenlineFont = Preferences.Font.dashed then
		   end if
	next
    End Sub
        End With
        Else
        End If
    End Function
    End Function
End Module
With best regards
Michael
