Journal to find file that doesn't contain a part attribute
cubalibre000
IT
someone has a journal that scan a folder with NX parts and find parts that doesn't contain a specific attribute ?
Thank you...
Using NX 8 and PDM RuleDesigner
Are you talking about a specific 'Part' attribute? I could probably write a simple GRIP program to do that, but it would have to wait until after PLM World since I'm still prepping for that and we're still doing the beta testing this week for the next version of NX.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
If you are trying to find a specific attribute try this, replacing 'Your_attribute' with the attribute name you are checking for
Dim theSession As Session = Session.GetSession()
Dim workpart As Part = theSession.Parts.Work
Dim check_string As String
Try
check_string = workpart.GetUserAttribute("Your_attribute", NXObject.AttributeType.String, 0).StringValue
Catch exc As nxexception
'set a boolean=false or whatever action you want if the attribute doesn't exist
End Try
Mark Benson
Aerodynamic Model Designer
To a Designer, the glass was right on CAD.
i've made this.
if they found some error with number five, they will create the attribute.
Code:
"on error goto asd"
your code here
asd:
if err.number = 5 then
workPart.SetAttribute("YOUR ATTRIBUTE", "VALUE OF ATTRIBUTE")
resume
else
msgbox(err.number & vbcrlf & err.description, title:="Error")
end if
Code:
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
public nome, pn, user, desc as string
Sub Main
Dim workPart As Part = theSession.Parts.Work
Dim printPDFBuilder1 As PrintPDFBuilder
printPDFBuilder1 = workPart.PlotManager.CreatePrintPdfbuilder()
dim msgtxt as string
msgtxt = "PROCESSO - GMP MARCATTO"
call setuser
on error goto asd
'workPart.SetAttribute("UGS_BR_NEW", "0")
if workPart.GetStringAttribute("UGS_BR_NEW") = 0 THEN
nome = inputbox("Programador:", "PROGRAMAÇÃO - GMP MARCATTO", user)
if nome = "" then
msgbox("Variável Não definida. Rotina encerrada.", title:=msgtxt)
exit sub
end if
pn = inputbox("Part Number:", "PROGRAMAÇÃO - GMP MARCATTO")
if pn = "" then
exit sub
end if
desc = ucase(inputbox("Descrição do item:", "PROGRAMAÇÃO - GMP MARCATTO"))
if desc = "" then
exit sub
end if
'DEFINE ATRIBUTOS------------------------------
workPart.SetAttribute("ELABORADO", nome)
workPart.SetAttribute("UGSBR_PROG", nome)
workPart.SetAttribute("UGSBR_DESENHO", pn)
workPart.SetAttribute("PN", pn)
workPart.SetAttribute("NOME", desc)
workPart.SetAttribute("UGSBR_REV", "01")
workPart.SetAttribute("UGS_BR_NEW", "1")
'MSG SUCESSO -----------------------------------
msgbox("Cadastro realizado com sucesso." & vbcrlf & _
"Programador: " & workPart.GetStringAttribute("ELABORADO") & VBCRLF & _
"PN: " & workPart.GetStringAttribute("PN"), title:=msgtxt)
ELSE
msgbox("Cadastro já foi realizado." & vbcrlf & "Caso queira executar novamente, mude a propriedade ""UGS_BR_NEW"" para ""0"" e execute a ferramenta novamente.", title:=msgtxt)
end if
exit sub
asd:
resume
else
msgbox(err.number & vbcrlf & err.description, title:="Erro")
end if
End Sub
extending the question,
can I read attribute from a file without opening the partfile.
Workpart will have an open file, I just like to know if and what attributes exist.
sorry new in NX
regards
Erwin
Sorry gmanucci, but your code is not what I asked.
Thank you...
